Golioth Zephyr SDK
fw.h File Reference
#include <stddef.h>
#include <stdint.h>
#include <net/golioth/req.h>
Enumerations
enum  golioth_fw_state { GOLIOTH_FW_STATE_IDLE = 0 , GOLIOTH_FW_STATE_DOWNLOADING = 1 , GOLIOTH_FW_STATE_DOWNLOADED = 2 , GOLIOTH_FW_STATE_UPDATING = 3 }
 State of downloading or updating the firmware. More...
enum  golioth_dfu_result {
  GOLIOTH_DFU_RESULT_INITIAL = 0 , GOLIOTH_DFU_RESULT_FIRMWARE_UPDATED_SUCCESSFULLY , GOLIOTH_DFU_RESULT_NOT_ENOUGH_FLASH_MEMORY , GOLIOTH_DFU_RESULT_OUT_OF_RAM ,
  GOLIOTH_DFU_RESULT_CONNECTION_LOST , GOLIOTH_DFU_RESULT_INTEGRITY_CHECK_FAILURE , GOLIOTH_DFU_RESULT_UNSUPPORTED_PACKAGE_TYPE , GOLIOTH_DFU_RESULT_INVALID_URI ,
  GOLIOTH_DFU_RESULT_FIRMWARE_UPDATE_FAILED , GOLIOTH_DFU_RESULT_UNSUPPORTED_PROTOCOL
 Result of downloading or updating the firmware. More...
Functions
int golioth_fw_desired_parse (const uint8_t *payload, uint16_t payload_len, uint8_t *version, size_t *version_len, uint8_t *uri, size_t *uri_len)
 Parse desired firmware description. More...
int golioth_fw_observe_desired (struct golioth_client *client, golioth_req_cb_t cb, void *user_data)
 Observe desired firmware. More...
int golioth_fw_download (struct golioth_client *client, const uint8_t *uri, size_t uri_len, golioth_req_cb_t cb, void *user_data)
 Request firmware download from Golioth. More...
int golioth_fw_report_state_cb (struct golioth_client *client, const char *package_name, const char *current_version, const char *target_version, enum golioth_fw_state state, enum golioth_dfu_result result, golioth_req_cb_t cb, void *user_data)
 Report state of firmware (callback based) More...
int golioth_fw_report_state (struct golioth_client *client, const char *package_name, const char *current_version, const char *target_version, enum golioth_fw_state state, enum golioth_dfu_result result)
 Report state of firmware. More...
Enumeration Type Documentation
◆ golioth_dfu_result
Enumerator
Definition at line 29 of file fw.h.
◆ golioth_fw_state
Enumerator
Definition at line 19 of file fw.h.
Function Documentation
◆ golioth_fw_desired_parse()
int golioth_fw_desired_parse ( const uint8_t *  payload,
uint8_t *  version,
size_t *  version_len,
uint8_t *  uri,
size_t *  uri_len
Parameters
payloadPointer to CBOR encoded 'desired' description
payload_lenLength of CBOR encoded 'desired' description
versionPointer to version string, which will be updated by this function
version_lenOn input pointer to available space in version string, on output actual length of version string
uriURI of the image, which will be updated by this function
uri_lenOn input pointer to available space in URI string, on output actual length of URI string
Return values
0On success
<0On failure
◆ golioth_fw_download()
int golioth_fw_download ( struct golioth_client *  client,
const uint8_t *  uri,
size_t  uri_len,
void *  user_data
Parameters
clientClient instance
uriPointer to URI string
uri_lenLength of URI string
cbCallback executed on response received, timeout or error
user_dataUser data passed to cb with each invocation
Return values
0On success
<0On failure
◆ golioth_fw_observe_desired()
int golioth_fw_observe_desired ( struct golioth_client *  client,
void *  user_data
Parameters
Return values
0On success
<0On failure
◆ golioth_fw_report_state()
int golioth_fw_report_state ( struct golioth_client *  client,
const char *  package_name,
const char *  current_version,
const char *  target_version,
Parameters
package_namePackage name of firmware
current_versionCurrent firmware version
target_versionTarget firmware version
stateState of firmware
resultResult of downloading or updating firmware
Return values
0On success
<0On failure
◆ golioth_fw_report_state_cb()
int golioth_fw_report_state_cb ( struct golioth_client *  client,
void *  user_data
Asynchronously push firmware state information to Golioth
Warning
Experimental API
Parameters
Return values
0On success
<0On failure
