Golioth Zephyr SDK
Golioth LightDB Stream
Functions
int golioth_stream_push_cb (struct golioth_client *client, const uint8_t *path, enum golioth_content_format format, const uint8_t *data, size_t data_len, golioth_req_cb_t cb, void *user_data)
 Push value to Golioth's LightDB Stream (callback based) More...
int golioth_stream_push (struct golioth_client *client, const uint8_t *path, enum golioth_content_format format, const uint8_t *data, size_t data_len)
 Push value to Golioth's LightDB Stream (synchronously) More...
Detailed Description
Functions for interacting with the Golioth LightDB Stream service
Function Documentation
◆ golioth_stream_push()
int golioth_stream_push ( struct golioth_client *  client,
const uint8_t *  path,
const uint8_t *  data,
size_t  data_len
Synchronously push new value to LightDB Stream.
Parameters
[in]clientClient instance
[in]pathLightDB Stream resource path
[in]formatFormat of payload
[in]dataPayload data
[in]data_lenPayload length
Return values
0On success
<0On failure
◆ golioth_stream_push_cb()
int golioth_stream_push_cb ( struct golioth_client *  client,
size_t  data_len,
void *  user_data
Asynchronously push new value to LightDB Stream and let cb be invoked when server acknowledges it or some error condition happens.
Warning
Experimental API
Parameters
[in]cbCallback executed on response received, timeout or error
[in]user_dataUser data passed to cb
Return values
0On success
<0On failure
