Golioth Zephyr SDK
Golioth Settings
Data Structures
struct  golioth_settings_value
 A setting value. More...
 Settings state data, placed in struct golioth_client. More...
Typedefs
typedef enum golioth_settings_status(* golioth_settings_cb) (const char *key, const struct golioth_settings_value *value)
 Callback for an individual setting. More...
Enumerations
enum  golioth_settings_status {
  GOLIOTH_SETTINGS_SUCCESS = 0 , GOLIOTH_SETTINGS_KEY_NOT_RECOGNIZED = 1 , GOLIOTH_SETTINGS_KEY_NOT_VALID = 2 , GOLIOTH_SETTINGS_VALUE_FORMAT_NOT_VALID = 3 ,
  GOLIOTH_SETTINGS_VALUE_OUTSIDE_RANGE = 4 , GOLIOTH_SETTINGS_VALUE_STRING_TOO_LONG = 5 , GOLIOTH_SETTINGS_GENERAL_ERROR = 6
 Enumeration of Settings status codes. More...
enum  golioth_settings_value_type {
  GOLIOTH_SETTINGS_VALUE_TYPE_UNKNOWN , GOLIOTH_SETTINGS_VALUE_TYPE_BOOL , GOLIOTH_SETTINGS_VALUE_TYPE_FLOAT , GOLIOTH_SETTINGS_VALUE_TYPE_STRING ,
  GOLIOTH_SETTINGS_VALUE_TYPE_INT64
 Different types of setting values. More...
Functions
int golioth_settings_register_callback (struct golioth_client *client, golioth_settings_cb callback)
 Register callback for handling settings. More...
int golioth_settings_observe (struct golioth_client *client)
 Observe for Settings. More...
Detailed Description
Functions for interacting with the Golioth Settings service
The Settings service is for long-lived persistent configuration data. Settings are configured/written from the cloud and read by the device. The device observes for settings updates, and reports status of applying the settings to the cloud.
Each setting is a key/value pair, where the key is a string and the value can be bool, float, or string.
Overall, the flow is:
  1. Application registers a callback to handle settings.
  2. This library observes for settings changes from cloud.
  3. Cloud pushes settings changes to device.
  4. For each setting, this library calls the user-registered callback.
  5. This library reports status of applying settings to cloud.
This library is responsible for interfacing with the cloud and has no knowledge of the specific settings.
Typedef Documentation
◆ golioth_settings_cb
Parameters
keyThe setting key, NULL-terminated
valueThe setting value
Returns
GOLIOTH_SETTINGS_SUCCESS - setting is valid
Otherwise - setting is not valid
Definition at line 1 of file settings.h.
Enumeration Type Documentation
◆ golioth_settings_status
Enumerator
Definition at line 45 of file settings.h.
◆ golioth_settings_value_type
Note that there is no "int" type because all numbers sent by the server are formatted as floating point.
Enumerator
Definition at line 68 of file settings.h.
Function Documentation
◆ golioth_settings_observe()
int golioth_settings_observe ( struct golioth_client *  client)
User applications should call this function in the on_connect callback, if they wish to observe Settings.
Establishes a single observation for the settings endpoint ".c". The handler for this observation will call the callback registered with golioth_settings_register_callback.
Parameters
clientClient instance
Returns
0 - Settings observation established
<0 - Error observing Settings
◆ golioth_settings_register_callback()
int golioth_settings_register_callback ( struct golioth_client *  client,
The client will be used to observe for settings from the cloud.
Parameters
clientClient handle
callbackCallback function to call for settings changes
Returns
0 - Callback registered successfully
<0 - Error, callback not registered
